It is currently Sun May 20, 2018 11:06 am
Post new topic Reply to topic  [ 11 posts ]
 Post subject: sattelite drift
PostPosted: Tue Apr 12, 2016 9:47 pm
If I use a 750 with basic guidance to mark bad bits in some drains and don't need to go back to them for 5 years will satellite drift change where I have marked by any great distance or will it stay within a given distance ? . Busy repairing some poor work done 5 years ago and need to mark where other drains join in if I can
Thanks
 Post subject: Re: sattelite drift
PostPosted: Tue Apr 12, 2016 10:13 pm
Thanks
It'll still be somewhere near, drift isn't accumulative, it can go one way one day and come back again the next.
PostPosted: Tue Apr 12, 2016 10:36 pm
thanks graybo , That might make it easier if it needs doing again
The guy that tied in the old drains to the new pushed the pipes so far in to the new one that it all choked up , I want to mark the joins but hopefully repaired properly wont ever need them
PostPosted: Fri Apr 15, 2016 7:32 pm
another question , I have fitted arial cables to 3 tractors and the sprayer and just wonder if there are screw on plugs that I can blank the end with to keep the weather and shit out ?
thanks
PostPosted: Fri Apr 15, 2016 7:55 pm
thanks
A blob of silicone?
PostPosted: Fri Apr 15, 2016 8:11 pm
Flintstone wrote:
thanks
A blob of silicone?
What's wrong with tape
PostPosted: Fri Apr 15, 2016 8:56 pm
silicone might be a job to clean out of the threads every time
tape would do the job if plugs not available
PostPosted: Fri Apr 15, 2016 9:07 pm
Yes you can get screw on caps, not sure where from, :scratch: , couldn't find any
on RS components website.
We went through a phase of using them, just use tape now.
PostPosted: Fri Apr 15, 2016 9:18 pm
thanks ,tape it will be then
PostPosted: Fri Apr 15, 2016 9:28 pm
Found them.
http://uk.rs-online.com/web/c/connector ... dust-caps/
PostPosted: Fri Apr 15, 2016 10:10 pm
thanks graybo ,will have to order when I next order from RS
 [ 11 posts ]
