It is currently Thu Apr 19, 2018 8:16 pm
Post new topic Reply to topic  [ 37 posts ]  Go to page 1, 2, 3  Next
 Post subject: Poorly Lawn Mower
PostPosted: Thu Mar 03, 2016 6:50 pm
My mower wont start, it doesn't appear to have any sparks. What do I need to do to make it work? It is a Tecumseh CTR40. I'm think new plug and HT lead
 Post subject: Re: Poorly Lawn Mower
PostPosted: Thu Mar 03, 2016 6:51 pm
Have you tried turning it off and then on again ?
PostPosted: Thu Mar 03, 2016 6:52 pm
I can't turn it on to turn it off and on again
PostPosted: Thu Mar 03, 2016 6:55 pm
It's FFuked.
Often best just to bung it into a repair shop and let them mince with it.
PostPosted: Thu Mar 03, 2016 7:08 pm
A Honda! :D
PostPosted: Thu Mar 03, 2016 7:38 pm
:thumright:
PostPosted: Thu Mar 03, 2016 8:47 pm
I have a John Deere ride on and it's never missed a beat in 10 years. Just saying. :lol:
PostPosted: Thu Mar 03, 2016 9:21 pm
Online
Mines probably forty years. One muffler, a couple plugs and a fuel pump.
PostPosted: Thu Mar 03, 2016 9:43 pm
I bought this secondhand in 2002 and your Homm Deere will have a Japanese engine in it. Just sayin'.
PostPosted: Thu Mar 03, 2016 9:57 pm
Yes it does, but the key has JD on it and the bonnet too. Just sayin (no g).
PostPosted: Thu Mar 03, 2016 11:31 pm
The float in the carb could be jammed
PostPosted: Fri Mar 04, 2016 12:47 am
My mowers going well. Did the back lawn last weekend. Just sayin
It's a mount field, and it has a honda engine.
My ride on mowers got a puncture though, and the mower deck is bollockesd - it doesn't like mowing tree roots
I'm nearly there......but not quite
PostPosted: Fri Mar 04, 2016 4:43 am
Missed the OP's small print there Dustin........................something about spark, lack of??
Salesmen.............................. :wink:
Check plug, most are resistive for suppression, swop it with one you know sparks.
Still no go, most probably electronic ign unless col's era, if points & condenser- check the points are not burnt,or dirty and condenser has a good earth
If electronic all you can try is make sure there are no broken/shorted wires
On both varieties check the off switch is switching both off and on ok. Finally check the ign coil its self is clean where the flywheel magnets pass by and also the outside edge of the flywheel. Coil will be earthed where it mounts on the cylinder block- a tarnished connection here is a common fault. If you take it off to clean, remount it with a 15-20thou feeler gauge between the coil and magnets- tighten fixings and then turn flywheel to extract gauge (some have a smaller gap but that should be ok). Finally check the plug lead. If it screws in to the cap and/or coil you should be able to see its copper wire, if it isn't it may be carbon again to help with antifierance and these can crack/become too resistive.
PostPosted: Fri Mar 04, 2016 8:10 am
Thanks FF
PostPosted: Fri Mar 04, 2016 9:08 am
Yes, I've often found a lack of a spark is caused by a jammed carburettor float...................... :roll: :D
 [ 37 posts ]
Post new topic  Go to page 1, 2, 3  Next
