Lorry brake stuck on
Tips, tools, repairs, rebuilds and fabrication.
Huffy
Post by Huffy » Thu May 04, 2017 8:55 pm
Yes.
When I parked her up a couple of years ago, the one wheel was a bit sticky .
Now the ffuk ing thing is seized solid . I put 3 and a half tonne of fert on it and towed her around ,backed up , shoved , jolted but still nought .
All the linkage on the handbrake were free and the pivots were back as far as I could get them but still the one side would not free off!!
Wheel off ,hub off but is there anything else I should try (other than firing the heap) ?
Somebody Stop Me
The Squire
Re: Lorry brake stuck on
Post by The Squire » Thu May 04, 2017 9:39 pm
WD40 :thumleft:
Flintstone
Post by Flintstone » Fri May 05, 2017 12:09 am
Have you tried turning it off and on again?
Paul Griffiths
Post by Paul Griffiths » Fri May 05, 2017 4:57 am
looks like a wedge brake ????
crook roller ?????
need to pull the wedge out if so
hope the shoes arent stuck in the drum if so its gunna be a big job
Paul
Huffy
Post by Huffy » Tue May 30, 2017 1:38 pm
Ahhh.
Yes , a final reply.
We took the wheels off and I thrashed seven bells outa the drum!!
The wheel would move an inch then jam and when I pulled the handbrake cable , it was rock solid.
Told son 'Thats it ,drum off time !!!!!!!!'
I went to fetch the big tool kit and as I returned he was shoving the wheels back on !!!
I asked what he doing and he said he just tapped it twice more and it clunked and away to go !!
8) Back of the net
Somebody Stop Me
