Charge light winking at me
Tips, tools, repairs, rebuilds and fabrication.
Huffy
Post by Huffy » Tue May 30, 2017 1:46 pm
Yes .
Well not exactly winking but on very dim , about 40% of the brightness with key on ,before firing up !!!
The alternator belts needed changing so I did them and put my spare alternator on .
Hadn't multimetered it before doing that (it wasn't flattening the battery but weather was warm ) but after changing , the light still stays on dim :|
Its doing 14.5 volts so no problems with charge I reckon.
Its a Mc Cormick CX 105 Extrashift (my loader tractor) Never seen it before ! (no the fault ,not the tractor)
I know a few years ago my Montego (what a classic!! :P ) would have its light stay on dimly but that was a bad and corroded connection on the multiplug!
So that 2 alternators the same ! (I think there was nothing wrong with the first ,mind)
The only thing ,apart from a bad connection on the 12 volt wire back to the keystart is some sort of damage to it somewhere??
What do the learned panel think ?? :)
Somebody Stop Me
JM
Re: Charge light winking at me
Post by JM » Tue May 30, 2017 3:43 pm
Bad earth? probably, possibly, hellif i know. :? :roll:
Just a Pembrokeshire twat.
Lord Muck
Post by Lord Muck » Tue May 30, 2017 7:49 pm
It's Ffuked.
graybo
Post by graybo » Tue May 30, 2017 8:42 pm
Have you tried taking it off and putting it back on again?
footsfitter
Post by footsfitter » Tue May 30, 2017 10:11 pm
sometimes its an alternator fault, but in your case having it happen on two different ones perhaps you have a short or a bad earth and something is powering up through the lamp. look at the damaged wire you were on about and also check earth straps between chassis and cab.
Paul Griffiths
Post by Paul Griffiths » Thu Jun 01, 2017 12:51 am
crook earth or ground or what ever you call it
Huffy
Post by Huffy » Mon Jun 05, 2017 11:35 pm
Thanks Peeps.
We know there is a bit of high resistance on the positive terminal as the starter motor is a bit lazy (tried changing it too) but thats been like that for a yr or so,and we havent had that fault on the charge light for more than 2 months .
As LM says , it might be ff uked :D
Somebody Stop Me
Huffy
Post by Huffy » Mon Aug 21, 2017 11:39 am
Paul Griffiths wrote:crook earth or ground or what ever you call it
Paul , we added another earth ground from the starter mount bolts back to the battery ,and it made no difference !!
My thoughts are a bit of corrosion (unseen) in the Pos lead at the battery .
We are going to add another positive lead in as well as the existing one , to see if it will cure the symptoms !
A bad connection might well be acting as a tight gate to the flow of electricity , but on a voltmeter will still show true voltage - hence why we get 14+ volts when charging .
I dont know :)
Somebody Stop Me
Huffy
Post by Huffy » Mon Aug 21, 2017 4:48 pm
Ordering a new heavier duty posi lead from Brucom 93 mm instead of 70 mm
Going to be about £40 - the Mc Cormick dealer wanted £85 for a new skinnier one .. :roll:
Somebody Stop Me
Huffy
Post by Huffy » Mon Aug 28, 2017 8:24 pm
Not ordered the new one yet .
Tonight , I went down the road at dusk with headlights on full and the hazard on . Charge light 50 % on
When in the field I noticed the hazard was revolving but the bulb was out .
Or was it? faint !! so I turned headlights out and it can on bright again??!!
Now surely the alternator would keep up with such a small demand on its own ,regardless of the state of the posi terminal integrity , or wouldn't it ??
Battery is good /newish ,in fact its had 3 in 4 yrs on it just to be sure . Charge voltage 14 .5 :roll: :?: :idea:
Somebody Stop Me
Huffy
Post by Huffy » Mon Aug 28, 2017 8:39 pm
I might add that the dealers mechanics -3 different ones , have looked at it over the last 3 times its been serviced by them !
Somebody Stop Me
