Spray Can Drain Trays
- Contact:
We have 2, black trays with a metal grill in them that have stiky uppy bits in that you put up turned spray cans on to drain them. Trouble is that the grills a rusty and I don't want to pour rusty water into my tank. Can I buy new grills, if so where from and if not, where do I get replacement trays from. I'm clearly not typing the right things into google
Re: Spray Can Drain Trays
Just pour the water down the drain Problem solved
You've obviously triple rinsed them all proper like, what with you being a professional operator so
as Tel said, tip it down the drain.
No one can steer like this Ffuker.
What are you poncing about with? Clean the cans with a good can rinse, then put them in a secure area before disposing of them in the approved manner on November 5th.
- The Squire
- footsfitter
2 things about one of them, theres a lot cheaper places than Spaldings and our sprayerman chucked it beind the spray shed in the end - the screw on can probes split/crack easily- the supplier replaced several a couple of times and then we were on our own with it.
