Wifi Issue Windows 10
Staffing, insurance, vets, computers and software.
The Pretender
Contact:
Post by The Pretender » Thu May 04, 2017 9:02 pm
The wifi on my laptop keeps cutting out with the little yellow exclamation mark appearing. Does the resident computer expert have any sage words of advise?
graybo
Re: Wifi Issue Windows 10
Post by graybo » Thu May 04, 2017 9:04 pm
It's ffuked.
Have you tried turning it off and on again.
Flintstone
Post by Flintstone » Fri May 05, 2017 12:08 am
The Pretender wrote:The wifi on my laptop keeps cutting out with the little yellow exclamation mark appearing. Does the resident computer expert have any sage words of advise?
I get this, usually late evening. BT have been ffuk-all use, wiser heads than me have suggested the modem is on the way out. Turning it offanonagain does seem to work.
I have two replacements on standby, you're welcome to one if you'd like it?
Raggy
Post by Raggy » Fri May 05, 2017 6:30 am
My laptop only picks up the wifi signal if I have the charging cable plugged in. Works a bit like an aerial.
Flintstone
Post by Flintstone » Fri May 05, 2017 12:09 pm
Raggy wrote:My laptop only picks up the wifi signal if I have the charging cable plugged in. Works a bit like an aerial.
With the other end plugged in to the modem? :D
Raggy
Post by Raggy » Fri May 05, 2017 1:02 pm
Haven't tried that one yet.
footsfitter
Post by footsfitter » Fri May 05, 2017 8:16 pm
Just left BT's yorkshire sibling Plusnet, their network seems to be set up to shut your speed down, sort of taper it down to what your using, ie light browsing, then when you click a biggish download it just seemed to take ages to get up to speed. Running a speed test seemed to confirm this- do a couple of tests but it would slink back to "just enough" later on.
footsfitter
Post by footsfitter » Fri May 05, 2017 8:27 pm
You could possibly have your power settings set to being a tight wad, now you can afford a bit of 'leccy have a look at your settings. If your on W10 right click the windows icon in the corner, Control panel, System & security, Power options, then click "change plan settings" of the plan your on, click "change advanced power settings" look for wireless adaptor- you can have different settings for when on the mains and on the laptops battery. I recently found after an update the laptop was going into eco mode as the battery started to drop making me think it was the ISP when it was just the power setting that had altered.
BTW when you do a speed test, it best to connect to the modem via a network cable so you get max speed, if your Wi-fi is arsing around and Openreach finds it that on a callout it could cost you a fee :wink:
The Squire
Post by The Squire » Sat May 06, 2017 11:52 pm
footsfitter wrote: Just left BT's yorkshire sibling Plusnet,
Who you with now?
NQIT
Post by NQIT » Sun May 07, 2017 6:30 am
Who you with now?
Don't tell her Pike!
She probably already knows. :)
footsfitter
Post by footsfitter » Sun May 07, 2017 10:33 pm
NQIT wrote:
Who you with now?
Don't be so rude Godfrey!
Returned back to Mr Murdocks gang. Having a permanent email address we can save a lot more than its cost and it allows you to up sticks and go without having the aggro of new addresses
The Squire
Post by The Squire » Sun May 07, 2017 11:06 pm
footsfitter wrote:
NQIT wrote:
Who you with now?
Can you not get a good deal if you stay?
Think I've been with 2 ISP ... while you've had 3 doz ... nearly! :roll:
footsfitter
Post by footsfitter » Mon May 08, 2017 1:00 pm
The Squire wrote:
footsfitter wrote:
NQIT wrote:
Who you with now?
some haggle a bit or put you over to "retensions" but often its the quality thats the issue, BT and +net both seem to choke speeds and only give you full chatt if your downloading something large- doing a speedtest will perk speeds up for a while but eventually it back to a click and then wait while the server must dawdle to find the address and connect at what it thinks may be needed?
Possible that either your paying more for bandwidth or there arn't so many punters connected in your area. For nearly a year we were getting 75meg in error from +net then about 8months ago they promised to upp our service to 36meg!! ended up going below 38 and at peak times the speeds to connect (ping) were then diabolical and the download speeds matched!
